Old 08-29-2015, 12:33 AM   #16 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
HS is heat spreader temperature. 270 is pretty cold. around 650 I think is pretty hot, like 75degC.
RT is raw throttle. 408 to 717 sounds fine. zero throttle is 717 and full throttle is 408.
FB is fault bits. zero is good. That means none of the bits are set. I forgot which bits mean what, but 0 is good. haha
CF is current feedback of the motor amps. On a scale of 0 to 510, where 510 is about 506amps. so it's almost 1-1.
Sounds like some awesome progress!!
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
thingstodo (08-29-2015)
