Whatever just happened, it looks like the fuel economy went up a bit with use over the last several tanks since the idling tank. It's a combination of that I used up the old "winter tank" gas and that I've just been using the car for long trips, and also (maybe?) that I just stuck some Iso-Heet in the fuel this last tank. I haven't filled up yet, though I can say the fuel economy (unless I now idle it away) is above 20 for this tank unlike the last two fill-ups. I haven't filled it back up yet.
Possible, still considered mods and ideas for future use:
Full Synthetic Fluids - ATF (Mercon V,) Power Steering Fluid (Which is ATF type F,) Engine Oil (0w30; May also use Archoil Friction Modifier) Gear Oil (75w90.)
These full synthetic fluids, I'm told, may indeed necessitate the use of a rebuild of both the engine and transmission which is why I haven't gone with them just yet. Got any suggestions, with 231.5k on the odometer? I think the odometer's a bit off though and reads higher than it is since the speedometer's 4 MPH too high at 55 MPH.
On-Demand Fan
Larger Tires
Also, to inspect and/or fix these:
Fan Shroud
Driver's Window (was acting up a bit though is closed now)
Inspect Suspension Bushings
Rust Bubbling Repairs (which there are a few to have removed and replaced with new metal and finish touch ups)
Speedometer Accuracy (reads +4 MPH too high as is)
Etc, Etc...
I'm going all out in my imagination, WITH a towing hitch. The previous owner did convert the A/C to R134, to speak a bit for his ownership of it.
