Originally Posted by MPaulHolmes
If you have to remove 5 of them, that still leaves 250amp at 125v of maximum power for a test. Just be careful with the DC throttle. If you cut out half of them, only push the DC throttle to no more than 50% of full throttle. full throttle will still try to command 500amp.
Is there no way to limit the output amps from the command line? Perhaps indirectly via battery amps?
