A close call. Is there any way one round hole in the pant would let you rotate the wheel and check each lug nut in succession?
Thanks fer the suggestion! It would be easier to just take the wheel pant off to inspect the lug bolts. Of course, it would be a whole lot easier and cheaper to just make sure they were torqued down correctly in the first place. I will just have to chalk this one up as a learning experience to make sure everything is properly in place and tightened correctly before buttoning it up. At least I can say I made a boo boo as well when it comes to tightening lug bolt/nuts.
So far, 4 new lug bolts at Tractor Supply Co cost me about $9 and a new replacement tire from Harbor Freight about $33. At least the trailer jack did the job I needed it to...and not a trip too late either!
I'm thinking about making the lower front support brace out of some tubing so it can't git deformed too badly if I back into the curb.
