Old 09-01-2015, 04:20 PM   #277 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by pearl62 View Post
Can you possibly share some basic dimensions of the MGR, length, width, height, etc?
I have made arrangements to get new batteries, and so now the floorplanning will begin, and I'd like to start thinking of how the MGR might fit in with my new pack...
Length: (from rear - output - bolt surface to front bolt center) 405mm
Length from output flange center to rear bolt surface: 100mm
Width: measured from output flange > output flange 272mm
Approxomite dimensions, because of it's lumpy organic shape:
Overall height: 290mm
Overall length: 420mm
Overall width: 325mm
Weight: 40.9kg; 90.2lbs (dry)
rated output torque ( of motor ) 130N-m
What new batteries are you using?
What's the output torque/power of your front motor?
- E*clipse
