Old 09-01-2015, 10:03 PM   #14 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Donahue View Post
with running 4, do you just turn 2 off for low beams? i thought projectors typically had moving shutters that were the difference between high/low. i know next to nothing about projectors other than i would love more light.
These LEDs are low beam only, but I do have a set of the reflector high beams from the Murano. I'll wire these up so all 4 turn on with the low beams. In a "bi-xenon" projector (high and low in one unit), the cutoff shield is wired to a solenoid and relay and flips down to let more light out when the highbeams are turned on.
Here's a GIF of bi-xenon projectors flipping between low and high:
These are 4 HID projectors. Nothing in the bulb output itself changes; the cutoff moves out of the way to get more distance from the light that's already there. In a lowbeam-only projector, the cutoff shield is fixed and does not move.
Originally Posted by H-Man View Post
I have reflector halogen highs and lows. It would scream rice if I had projectors.
On my last car, I retrofitted Morimoto Mini H1 projectors into the reflector housings; I thought I had a picture of it but can't find it on my computer. It didn't look all that bad.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
redpoint5 (10-11-2015)
