Originally Posted by darcane
You can peruse the thread in my signature for ideas. I have an '01 HX.
When lean burn engages it feels like the engine stumbles just a little and makes a little less power. When it disengages, there is a slight surge. It's very subtle, and likely you won't notice it until you get a gauge to verify when it happens.
The MPGuino will be most accurate, but I like the Ultragauge for the wide range of useful features at a very reasonable cost and easy install. I'm just aware of the fact that it is inaccurate under lean burn and don't put much faith in it if I use lean burn a lot. When I do use lean burn a lot, my mileage for the tank is higher than what is reported on the Ultragauge.
so what you are saying is, the ultra gauge is very useful, but use another method at fillup to determine average mpg?
