Originally Posted by BabyDiesel
Welcome!
If gearing doesn't matter and you're getting new wheels... Have you considered with going with a 14" wheel if it can fit past your brake calipers? I ask because you can then run 165/65R14 Bridgestone Potenza RE92 LRR tires. These give the best fuel economy, hands down my man!
And yes, 2k revs from a stop gives you lots of friends... Especially those who wave at you with one finger...
Tried to source some of those tyres you speak of locally but apparently its an older model and we no longer have it (maybe just in Aus?). So will have to delay the tyres.
So this is the first, of what I'm sure will be many, rear wheel arch cover mock up.
I'm toying with keeping the rear of it vertical to try and obtain a "Crease" in the rear of the vehicle that phil knox referred to in a document.
