Old 09-05-2015, 12:08 PM   #325 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Ardent View Post
Hmm, didn't know that was even possible; that does sound magical!
On my engine my intake boost is more then exhaust pressure anywhere from
1 psi to 4 psi. On another compound DSM Kevin Jewer's 7 second 1/4 mile Talon hes running a much higher rpm then me and a lot more power around 1300HP at 9500 rpm, and at this high rpm hes only 1 psi to 3 psi more back pressure then intake boost.
EDIT:
Engine Load is intake pressure
Primary Load is exhaust pressure
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Ardent (09-05-2015)
