Lids prepped, time to take on the batteries and boxes.
Bolted the first set of 12 together, with BMS wires.
I stripped an inch away from the BMS wires, wound the ends into loops around a screwdriver stem, soldered it rigid and put them over the terminals hemmed in between double connector plates.
The cells are quite small, the danger of shorting between cells was making me nervous. So I cut plastic strips from food boxes and bent them over each connection.
Just in case I'd drop something on the terminals...
I don't aim for making it 100% fool proof. But it is nice to have it
me proof!
Two thirds in I let the wrench slip from my fingers and it fell right on top of the battery!
The plastic did its job, no harm done
Goes to show you can't be too careful!
