config (or settings) can show anything you want! How about this for starters:
config
p=xxxxx i=xxxxx
min-regen-position=xxx max-regen-position=xxx
min-throttle-position=xxx max-throttle-position=xxx
fault-throttle-position=xxx
max-battery-amps=xxx max-battery-amps-regen=xxx
max-motor-amps=xxx
current-sensor-amps-per-volt=xxxx
precharge-time=xxxx
rotor-time-constant-index=xxx
raw-throttle-position=xxx
(any others that come to mind?)
