Old 07-30-2008, 05:41 PM   #17 (permalink)
modmonster
Tracy - '00 vauxhall corsa
AX where did you buy the plastic? and how did you get it home? any continuous sheet big enough for the under belly of a car probably wouldn't fit in it. did you have to bend it? or was it already cut up into managable chunks? if so how did you join them together without having the joins mess up the aero?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
