Old 09-09-2015, 04:36 PM   #1964 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by MPaulHolmes View Post
config (or settings) can show anything you want! How about this for starters:
config
p=xxxxx i=xxxxx
min-regen-position=xxx max-regen-position=xxx
min-throttle-position=xxx max-throttle-position=xxx
fault-throttle-position=xxx
max-battery-amps=xxx max-battery-amps-regen=xxx
max-motor-amps=xxx
current-sensor-amps-per-volt=xxxx
precharge-time=xxxx
rotor-time-constant-index=xxx
(any others that come to mind?)
Looks good. How about raw-throttle-position? It would help if there is a throttle fault to know whether it is high or low, and to see if it changes when you change the position of the throttle.
The Following User Says Thank You to thingstodo For This Useful Post:
e*clipse (09-09-2015)
