Old 09-09-2015, 04:05 PM   #1968 (permalink)
e*clipse
Permanent Apprentice
config (or settings) can show anything you want! How about this for starters:
config
p=xxxxx i=xxxxx
min-regen-position=xxx max-regen-position=xxx
min-throttle-position=xxx max-throttle-position=xxx
fault-throttle-position=xxx
max-battery-amps=xxx max-battery-amps-regen=xxx
max-motor-amps=xxx
current-sensor-amps-per-volt=xxxx
precharge-time=xxxx
rotor-time-constant-index=xxx
raw-throttle-position=xxx
(any others that come to mind?)
Originally Posted by thingstodo View Post
Looks good. How about raw-throttle-position? It would help if there is a throttle fault to know whether it is high or low, and to see if it changes when you change the position of the throttle.
Maybe Temperature sensor stuff?
Also, I'm using a Prius throttle - there's both a high and low output fault zone. It also has two sensors that it uses *somehow* to detect if the sensor's working.
Also, you might have different configurations based on the configurations... For example, I'm going to use this with a 'Yota Interior Permanent Magnet motor. As far as I know, the rotor time constant isn't an issue. So, there might be a "motor type" configuration, with each motor type having specifics like a rotor time constant.
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (09-09-2015)
