Originally Posted by MetroMPG
It's also worth checking the undertrays. I don't know about the Volt, but OEM ones I've seen (Mirage, 2g Prius, Insight) often leave a lot of room for improvement. And since they're plastic, there's no harm in putting screws into them to add more/smoother coverage with sheets of plastic (eg. coroplast).
The 2011/12 model year Volts have more complete undertrays than 2013-2015. Unfortunately while they will physically fit, the 13/14/15s don't have the mounting studs welded in place as with the 11/12s.
