Old 09-10-2015, 12:04 AM   #67 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
You should check out my thread on the G1 Insight. I've had basically every issue stereotypical of the car, and nearly all of them were quick and simple fixes.
http://ecomodder.com/forum/showthrea...ild-29288.html
Lean burn took me a while to figure out, but here's my basic understanding of it:
In 5th gear, accelerating with 100% load, you're at 45-50mpg. If you let off the pedal gradually until you reach ~100mpg, after a moment the car will drop into lean burn and shoot up past 150. You can then press the pedal back in to around 75mpg. Anything beyond this and you're at ~100% load again and it will drop out of lean burn and begin electric assist.
Have you done anything with index the spark plugs? I have some left over index washers that would work and I'm thinking about trying them. Thoughts?
Pressure Gradient Force
The Positive Side of the Number Line
