Old 09-10-2015, 09:31 AM   #6 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by iamnotahippee View Post
They are actually 4 ply extra load tires. That means the recommended inflation is 50 psi. Of course mine are at 30-35 psi. Tomorrow i will go air them up to the proper level. I imagine 15-20 psi could definitely gonna be a problem.
Check the rated pressure - you might be able to go even higher than 50psi
It'll feel stiffer, but as long as the ride doen't get bouncy, you're fine.
Check wear pattern on tyres periodically.
Try a scrapyard for roofrail caps
