Old 09-11-2015, 11:55 AM   #6 (permalink)
ISV-2K8Rondo
Telescope Transporter - '17 Kia Forte 5
Got my second tank after "adjusting the nut behind the wheel" and bumping tire inflation up to 40 psi (35 psi recommended, 44 psi max. sidewall). Result was 26.9 mpg. I had to use the A/C much of the time as it's been unusually hot here in Ohio for September.
This tank will have less A/C use for sure. It's cool enough in the mornings to just use the vent. Which begs a question--what's the impact of using vent vs. using A/C, and how much does the temperature setting of the A/C affect fuel economy?
I've taken all extraneous items out of the Rondo, but it wasn't much; maybe 20 lbs. total. What I haven't taken out is the (a) the spare tire and (b) the roof rack, though I did get a can of Fix-A-Flat. I figure I'm saving more than enough gas in a year to justify my AAA membership if I need the car to be towed, anyway. The spare tire and the roof rack combined would, I think, yield FAR more weight reduction than 20 lbs.
Problem with the roof rack is that I simply can't take the cross beams off. I more or less have to remove the OEM roof rack as one unit. I know how to do that; it's plugging the holes I'm not crazy about.
What kind of mileage boost would I be looking at if I removed the entire assembly? Like 1% or 2%?
--Phil
