Old 07-30-2008, 05:26 PM   #13 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
That was prescient of you.
His latest update is about how the plastic is too thin and soft, and was deforming in the heat and at speed.
Last Vetter Fairing - Fuel Economy -P12
He even did the "like over-lapping roof shingles" trick with it..
But, he didn't try using multi-layers.. If he could have used some spray
adhesive between the layers that would cure in-place (with the curvature).
That might have had more firmness. Even just two layers would might have
worked better.
I've made RC model gliders and airplanes covered with thin plastic called
monocoat Covering Materials - Iron-On Plastic
It's heated with a heatgun or iron until it's really tight and won't flop around under wind loads.
I'm wondering if maybe 6 or 8 layers of Monocoat would work for his application?
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
