Previa's and Delica's from Japan are great... pre-fukushima import!
If your going to use the lasercut plywood for construction, longitudinal and/or diagonal tension cables would strengthen it. Or interlocking puzzle pieces. Plus a rigid skin.
Nice, a steel cable\chain should add some security.
I also see what you mean with the hemispherical body and putting the load on the axle.
Originally Posted by nimblemotors
Those might be cheap-ish when your labor is free, but most CERTAINLY not looking like a million dollars!
The early Mazda MPV van was available in 4wd, and is a narrow van,
that would be better for aero, but frankly why a van to convert to truck,
just use a truck if that is the idea.
Any of these builds would be 1000's of hours of work.
This MPV has nice proportions and can look good with a kit...
http://i.imgur.com/FB1JODA.jpg
but I dont think any kind of RV or vehicle is available to buy with such a uniform bullet shape thats like the Previa combo. I challenge anyone to find something similar
