Not sure what the defaults are, but these are the settings that come up when the controller powers up
AC controller firmware, ver. 1.0
config
p=14000 i=00225
current-sensor-amps-per-volt=0027
max-regen-position=0025
min-regen-position=0400
min-throttle-position=0624
max-throttle-position=0972
fault-throttle-position=0005
max-battery-amps=0050 amps
max-battery-amps-regen=0010 amps
max-motor-amps=015 amps
max-motor-amps-regen=015 amps
precharge-time=0005 tenths of a sec
rotor-time-constant-index=030
pole-pairs=002
max-rpm=06000 rev/min
throttle-type=0
encoder-ticks=0512 ticks/rev
stator-resistance=01024 mOhm
stator-inductance=00307 mHenry
pack-voltage=124 volts
pi-ratio=062
raw-throttle=0000
