Old 07-30-2008, 06:22 PM   #16 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Originally Posted by CobraBall View Post
Aircraft fly high for two reasons. Less air with the same air to fuel ration burns less fuel. Higher altitude (colder) the higher the true airspeed.
That just means that they have fewer HP available. A throttle does the same thing. Piston engines often have superchargers that would blow the heads off at low altitude, that are used to help burn more gas up higher, for a faster, but less efficient cruise speed. The altitude does help with reducing drag and avoiding weather.
Colder air is denser, which gives both more drag and more lift.
