The Honda Grom looks impressive. Apparently it can attain speeds of up to almost 65mph. I bet that with a major aerodynamic overhaul it would get quite a bit better fuel mileage or even top speed. Integrating a turbo would be cool and help Keep from wanting to stay in low gear. But I wonder how hard it would be to pull off the task of adapting a turbo to this bike and what the actual out come would be.
First of all I'd have to find space for the turbo and possibly intercooler plus all the plumbing. With added intake pressure there would likely be a need for a larger injector and changes to the ECU. Also there would be the need for better cooling, perhaps through oil sprayers inside the engine and an oil cooler.
I wonder if a small electric motor and high output lithium battery wouldn't be a better option for better acceleration, not to mention regenerative braking.
