Old 09-13-2015, 07:03 PM   #252 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
Oh goodness! I know my write up isn't the best
I'm having a blast driving the car now! Lean burn is... Weird lol. I flip the switch and the power crashes, mpg goes from 45 to 70ish, and I am all smiles! I'm about to go put and drive right now!
Just curious, is my car suppose to stay in closed loop in lean burn?
I'm not sure on your setup how Tygen set it up?
On my Talon I can run it in closed loop or open loop. Closed loop only gives me around 17:1 A/F do to the O2 cycling. This can cause a miss fire with anything leaner while in closed loop.
On my Insight, "still to new to me" but I think it runs in open loop during lean burn and drops to closed loop stioch after x amount of time to cycle the CAT to keep it happy.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
BabyDiesel (09-13-2015)
