Old 09-13-2015, 08:57 PM   #256 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
It looks like the PCM is thinking there's a issue with the fuel pump, or injectors, or fuel regulator because the air flow voltage is correct based on the MAF but the O2 always has the last say.
Can you toggle before 10 minutes and let everything go back to normal? The STFT should adjust quickly. Then flip it back to lean burn? Basically make the PCM happy.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
BabyDiesel (09-13-2015), MobilOne (11-12-2015)
