Old 09-14-2015, 07:07 AM   #18 (permalink)
lasitter
Originally Posted by CapriRacer View Post
That leaves only the 235/75R15 General Grabber HTS.
Now your current Kumho Solus KR21's are so very similar to the General Grabber HTS's, I don't think you will experience any improvement in fuel economy. In fact, if you make this change, you will start off WORSE, and it will gradually get back to where you are now - worn tires.
It all boils down to a couple of things:
Do LRR tires by General roll any easier than non-LRR tires from Kumho? Factor: The new tires would weigh 3-4 pounds more.
And: This would be offset by the new wheels being up to eight pounds lighter than the existing ones.
More research / other possibilities ...
Firestone Destination LE2 HAS --- P235/75 R15 108T XL 2183 lbs./50psi 12.0/34" 34lbs 7.4"
Two pounds heavier, but a much more highly rated tire than the Grabber HTS. Probable difference from the Grabber in fuel economy?
I don't have revolutions per mile for some of the tires in the list, and I'll work on that today.
