Old 09-14-2015, 09:51 PM   #2002 (permalink)
e*clipse
Permanent Apprentice
Originally Posted by MPaulHolmes View Post
The FOC code is running through over 10,000RPM (2 pole pairs) in order to produce 5,000RPM of revolution. That may be too fast for the 10kHz control loop... I wonder if we should bump the A/D readings up to 20kHz, and do the IGBT switching still at 10kHz... That would mean needing to boost the microcontroller frequency from 14.7MHz up to 29MHz. That's no big deal. It's a 30MHz microcontroller. Fortunately you don't need to go over 10,000RPM mechanical! haha.
This is one of the reasons I'm interested in SiC switches. The motors I'm using can run up to about 12,000 or maybe 13,000 rpm. I'd like to make use of their capabilities like this.
It seems one would also want to increase the switching frequency to have good resolution at those speeds. Perhaps a motor speed adjustable switching frequency??
- E*clipse
The Following User Says Thank You to e*clipse For This Useful Post:
MPaulHolmes (09-14-2015)
