Old 09-14-2015, 10:23 PM   #2003 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
The nice thing about the dspics is you can change the switching freqency every stinking cycle and it doesn't mind one bit. The only concern I would have is the code would have to run a tiny bit slower, since I optimized a few things to 10KHz, so as to avoid doing a couple integer divisions, which take 17 clock cycles. But if I still have a lot of room at 14MHz. And then have tons of room at 28MHz.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
e*clipse (09-15-2015)
