Old 09-15-2015, 12:15 AM   #2004 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Update for Sep 14
Took the DC and AC controllers off the mounting plate (separated Cougar controller), remove the mounting plate - was mounted over both motors
Move the AC controller (still connected to the AC motor)
Remove the motor supports (most of them)
Decouple the motors
Pack up for the night
- located some of the parts required to make a small circuit board out of the voltage divider network for the encoder
- it does not appear that the netgain warp 9 can reliably withstand a 10,000 rpm test. So I decoupled the DC motor and now need to get the encoder coupled to the motor directly .. after I figure out where to put the DC motor for a few days.
ID:	18724   Click image for larger version
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (09-15-2015)
