Old 09-16-2015, 03:02 AM   #23 (permalink)
oil pan 4
There should be an adjustment screw to turn the engagement temperature up or down on the fan clutch.
Try that first, get the fan clutch to where the thermostat can open most if not all the way then have the fan come on once passive air flow isn't enough to cool it down.
We had a guy that would take stock duramax fan clutches, turn the engagement adjustment screw down 5 or 10 degrees, resell them for $100 more as up "grade fan clutches" for 6.2L and 6.5L diesel engines.
