Old 09-16-2015, 09:25 AM   #12 (permalink)
adam728
adam728's Avatar
Mazda3 - '08 Mazda 3 S
90 day: 29.65 mpg (US)
DR650SE - '13 Suzuki DR650SE
90 day: 46.16 mpg (US)
Wife's - '12 GMC Terrain SLE-2
I think the first thing you need to do is decide what truck you want to start with. That will drive a lot of the other decision making. For example, 7" of lift on an S-10 chassis requires major surgery to keep driveline and steering angles in a happy range. 7" of lift on a TTB Ford is easy. But having adjustable ride height on that TTB suspension will be nearly impossible due to major camber changes throughout the travel.
Swaybar disconnects are not a necessity when adjusting ride height. But man can they make the ride off road better, and typically increase vehicle capability by allowing much more flex.
In the end, I do not see the feasibility of this. 14" of adjust ability is massive. And 3 different sets of tires? Where's the economy in any of this?
I am a fan of picking a tire size, then keeping the vehicle as low as possible to fit them. If you put 35" tires under a truck, your axle/differential clearance is now set. Raise or lower to your hearts content, it won't change that dimension. Now, lifting will increase approach/departure/breakover angle clearance.
