Old 09-16-2015, 01:01 PM   #2019 (permalink)
e*clipse
Permanent Apprentice
So, according to Paul, it sounds very possible to not have a whiny car. It also sounds like one could easily adjust frequency according to operating parameters. Thus, one could have a daily driver/ track car that could be quiet for commuting, and (in another mode) make use off all power potential (but be whiney and less efficient). Awesome!
thingstodo:
The motor inductance, actually the impedance since there is resistance as well, is a pretty effective low pass filter. The control *SHOULD* not be much different at 16K versus 8K.
The best info I can find is the inductance for the motors I'm using is very low - 1.4mH to about 3mH ( It varies due to phase angle, I think )
What's the inductance on the big ( 75hp ) motors, in general? Isn't motor inductance lower at higher power levels ( in general ) It seems as the inductance decreases, the smoothing would work better at higher frequencies. True??
- Thanks,a bunch,
E*clipse
The Following 2 Users Say Thank You to e*clipse For This Useful Post:
MPaulHolmes (09-16-2015), thingstodo (09-16-2015)
