Originally Posted by aardvarcus
I assume you are going to be using a modified clutched alternator?
The specifics to that are here:
http://ecomodder.com/forum/showthrea...tch-32660.html
The term clutched alternator is a little bit misleading. As far as I can tell there are 2 types of OEM clutched alternator. A one way clutch and an dampener clutch.
Neither actually stops alternator rotation.
