Old 09-16-2015, 04:39 PM   #7 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
As part of the general going over I did the usual fluid level checks.
Coolant/brake fluid all spot on, jowever the Oil level was ABOVE maximum..
This is a sign that the WVO is getting past the piston rings- and collecting in the sump.
The car is still running well, no obvious running issues and no MPG drop
Obviously this is not ideal! I took the most sensible path possible, based on the fact that it is a supercheap beater -
I dropped some oil out the sump and topped it up to max with fresh oil.
Over the last 4000miles it appeared to be approx 500ml- will keep an eye on it.
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
