Here are some pictures of the Warm air intake.
The stainless steel clam shell surrounds the catalytic converter and directs the warm air to the intake. I try to maintain 120 degrees at the intake
The O2 sensor to the left is the one I added so I can be sure of when the engine is in lean burn with the gauge on the dash
2 1/2 " silicone duct carries the warm air to the intake and also draws in fresh air to adjust the temps with the exhaust cut out valve .
