Old 09-17-2015, 06:09 AM   #1 (permalink)
iceyinferno
Dino - '93 Honda Civic DX
90 day: 43.65 mpg (US)
White Shadow - '15 Toyota Prius C Two
90 day: 50.69 mpg (US)
1994 Civic VX hatchback - $1600
UP for sale 1994 Civic VX Hatch. 173k miles
Located in Owings, Md 20736
Car has the following new parts:
oil pan gasket
rear main seal
clutch
flywheel
throwout bearing
cv axles
radiator
radiator hoses
thermostat
timing belt
water pump
alternator
battery terminal wires
battery
fuel filter
transmission oil changed
Cold a/c and hot heat
easily gets over 35mpg
gsr cloth front seats
The bad:
SRS light is on
Front left tire has a slow leak
Some rust over rear quarters, was repaired by someone in the past...but not well
Few dents in hood and hatch
lean burn mode causes misfire and studder...has check engine light on since I disconnected the O2 sensor to prevent lean burn mode from engaging.
For full asking price you'll get an additional engine and an additional ecu.
pics in craigslist ad: 1994 Civic VX hatch
