Old 09-17-2015, 08:44 AM   #2 (permalink)
MPGomatic
Needs More Duct Tape
MPGomatic's Avatar
Slambo - '99 Honda Civic HX
90 day: 44.21 mpg (US)
I'm digging the resin-coated idea! You just lit up a big light bulb over my head.
What if you added a thin layer of foam and a layer of resin resistant material between the underside of the car and the composite weave? That would provide a wee bit of spacing so the tray wouldn't stick during the impregnation process or rub after installation (with rubber grommets or washers for spacing).
Once this is laid up, it might be used to make a mold to produce additional pieces.
It sounds like the material that your friend has in the fridge is "prepreg" … it's quite pricey and needs to be heat cured.
Originally Posted by Tulok View Post
So my friend has this carbon fiber roll that he has to keep in the fridge. Basically, when you take it out you have a few minutes to cut it to size, wrap it, lay it, whatever you want, and then heat it with a heat gun to harden it completely. I was trying to find out where he got it from, but he's really busy and I don't live next door anymore so it's hard to keep in touch.
Anyways, I was thinking of making flat undertrays by fastening it in between the frame rails of a car with large rivets or bolts or something, then I realized that I could probably just use heavy duty fabric.
Why couldn't I use some fire proof canvas or fiberglass cloth and make a whole undertray? By stretching the fabric tight and bolting or by making wedges to pinch it along the edges it should be strong enough to not flap in the wind.
I know isn't 100% air tight, but it's also not 100% "heat tight" so it may be a good compromise between ventilating transmissions and exhausts and not letting air get all turbulent underneath the vehicle.
Another Idea I had was to make the thing, then coat it in resin with a brush, a few layers to firm it up. then I would be able to cut out or louver it in areas that need venting. it would also retain it's shape when taken off of the vehicle that way
Thoughts?
Ain't Fuelin' - The Beater Build Show :
https://www.youtube.com/playlist?lis...R754kIg_V8Aahm
