Old 09-17-2015, 10:25 PM   #1 (permalink)
roosterk0031
Convertying Non-FFV to FFV (Flex Fuel Vehicle / E85)
2007 Chevrolet HHR
Following his experiments I'm going to convert my Cobalt XFE (or really just enable) the FFV feature. After 5 years of owning a SG2, I finally figured out the xgage features so I can see Long Term Fuel trim, HP, A/F and Knock Retard. My test drive was with E10 LFT was around 3 most of my 15 mile drive. made 100 hp at 4,000 rpm, 0 knock retard, A/f 14.6.
I went and topped it off with almost 8 gallons of E85 making an E55 blend after just a few block LTF was in the 20's but it jumps all over(3-28). Didn't expect it to move around that much. A/F 14.6.
What I think will happen is the car will learn the new fuel and reset the LTF to 0 so that it doesn't throw a CEL with LFT exceeds 30 or so, I don't really know the % when it throw but in the past anything over E55 would throw a CEL.
Sometime next week I'm going to(pay someone one else to using EFIlive) turn on the FFV feature that is already in the ECU and make some small tweaks to the timing maps, maybe some tweakes to fueling.
Same year/engine/tranny HHR has the same everything but is a FFV so using it for a baseline. If it works well, then KT's Cobalt.
The Following User Says Thank You to roosterk0031 For This Useful Post:
ME_Andy (09-17-2015)
