Old 09-18-2015, 02:56 AM   #12 (permalink)
markweatherill
Send a message via MSN to markweatherill
Originally Posted by Grant-53 View Post
an air supply.
I just imagined a package mounted at the rear of a car, like a deflated and rolled up air mattress in construction. It's attached to the tailpipe, with its own ventilation outlet(s) so the gases will pass through it.
You start the vehicle, it begins to inflate into shape and stays up while the engine is running. Now, when you switch off the engine, it deflates and by some clever elastic cord arrangement, more or less folds or rolls itself back up.
It must have valves to relieve excess internal pressure, it must drain any condensation, and must be proof against corrosion.
