Old 09-18-2015, 10:24 AM   #274 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by BabyDiesel View Post
I'm probably being over-analytical when I say I need a rebuild It seems almost wrong to turbo a car with 280,000 miles on it!
This is the slightly used Wideband O2 I am buying today off of a part-out at TeamZX2.com for cheap -> Wideband Air Fuel Ratio Gauge
Russell, can this O2 take place of my stock narrowband? Or do I have to run both?
Usually you will need a after market management system that will have Narrow Band O2 Simulation. Then you have to set voltage up in this software.
I would just weld in an extra O2 bung and run it with your narrow band. If you ever sell the car they make a O2 bung plug that comes with the bung.
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
BabyDiesel (09-21-2015), MobilOne (11-12-2015)
