Old 09-18-2015, 06:08 PM   #41 (permalink)
secaturbo
2005 Insight
The hose under the battery (closest to Batt?) is the one I needed the know-thank you.
Gonna try the Kats to see if the convection of heat will work. I think it might as you said :
"the water up to a tee into the heater core return line and from there the water bypasses the thermostat and circulates through the engine".
Hoping that bypassing the thermostat will allow enough convection/circulation.
The Following User Says Thank You to secaturbo For This Useful Post:
TDFbound (11-20-2018)
