Old 09-18-2015, 09:58 PM   #10 (permalink)
oil pan 4
I presented my solution to boosting voltage a few years ago:
Take a 6 and a 8 volt deep cycle battery of the same make and size and wire them in series.
A 7 cell battery should have a 14.9 volt open current resting voltage, should be considered "dead" at 12.2v. Under load I would expect a 7 cell battery to have about a 14.4v, +/- 0.2v under load.
Only problem I see is you would need to devise a special 17 volt charger to charge them up. Or attach each one to its respective 6 and 8 volt chargers.
Or go with a LiFePO4 battery. Normal volts for 4 cells is 13.2 and 12.7 is considered "dead".
For voltage dips causing dimming head lights use LED.
My LED head lights are full brightness down to about 11 volts and draw 7 less amps in low beam.
redpoint5 (09-19-2015)
