Originally Posted by Baltothewolf
Can I get a link to the supercharger you used?
The Supercharger itself is from a Mazda Millennia you can google that and get more info about it specifically. But to give you a little starting info on it this Supercharger is the Lysholm-type supercharger in the Eunos 800M (aka Mazda Millennia). These are around 75% efficient which puts you right up there with current turbo chargers. These are an extremely good choice for running anything upwards of say 18psi anything over 18psi and you will get more of an advantage out of a turbo charger.
The Lysholm-type supercharger is manufactured by IHI. The twin-screw compressors feature a Teflon coating and are made from lightweight alloy. To my knowledge there are four common sizes that displace 750cc, 1000cc, 1500cc and 1840cc per revolution. The one I used specifically is the 1000cc version. The 800M supercharger measures approximately 40cm long, 17.5cm wide and 15cm tall.
I hope this helps you out a little bit.
