There are an infinite number of squircles between the circle and the square. One of them will be the closest match to the profile of the New Beetle at the A-pillar. These are not it*, at 50/50. Something about 65-75% toward a square would be closer. The rear quarter windows should be unobscured.
The lower body is held to the original overall length; the wheels are covered and the 'shoulder' is moved forward for aero reasons. The upper body is sized to the length of the rear hatch and could be extended.
*Truncated, widened and stretched to fit.
Freebeard, this image represents the initial profile of my trailer as I see it, thank you.
I hope to get the air stuck back onto it behind the beetle as soon as I can. The big challenge is how I can taper/transition the three curves into one that gets as template C-like as I can by the ending out of the trailer.
Washing out those sharp inside corners will be fun.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
