Originally Posted by spacemanspif
.... Pop the hood on a car built in the last 10 years and if it's anything above an entry-level vehicle, underhood is a plastic cover trying to convince the owner not to remove it and see the complicated mess of wires and hoses running every which way and seemingly designed to keep normal people from doing their own work.....
In most cases..
That's not the case with 2005-2010 V6 Mustangs. Under the hood is an ENGINE with no covers. And the engine is not "sideways".
You can see the ground in front of; and on both sides of the engine. If you drop a tool while working on it, it may roll underneath to exact center, but it WILL hit the ground.
And there's plenty of room to get to the spark plugs when I need to change them... in about 31,000 miles.
