Old 09-20-2015, 08:10 AM   #15 (permalink)
hamsterpower
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
Originally Posted by P-hack View Post
It is a function of the size of the motor, so yes, but it is gonna be heavy IF YOU HAVE NO GEARS!!!
The tesla roadster has about 8.25:1 gear ratio IIRC. But you are not going to find a motor that can drive a single speed gearbox AND lift a heavy homebuilt thingamabob offroad rock climbing AND push it down the hiway. Multiple gear ratio choices certainly would be a good call there.
electric motors arent magical. And adding volts adds weight for a given torque, so less climbing.
He said top speed would be about 30mph, so no highway speeds needed. He also is talking about a rock crawler so the range only needs to be a few miles per charge. so no big battery packs needed. With a diesel genset and a reasonable lipo pack and a small tube frame it could be fairly light and compact. Accumulators would help, its a way to regen and brake with hydraulics instead of the EV parts. Also with hydraulic drive that eliminates the need for mechanical gearing.
