Thread: beetle kammback
Old 09-20-2015, 07:51 PM   #47 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Evolution of a kammback
First pic shows the basic line moved aft per Aerohead's suggestion that I was forward of separation point. Of course the final product would have a curve there.
Next few the basic cardboard is on, shows that relationship between kamm and sunroof, etc.
Back is too square for a curvaliscious car like the beetle.
Added a curved tail, with view from behind too.
Final has the Colani curve tacked on. I think it will move aft and there will be more kamm there at the notch.
The bottom end can go aft farther without impeding views. I could also add a shelf wing down there out of sight if I can make it work.
None of it was visible in the mirror, only when I turned to look back and to the right, and it could go a little more aft as you move up the trailing edge.
ID:	18768   Click image for larger version
ID:	18769   Click image for larger version
ID:	18770   Click image for larger version
ID:	18771   Click image for larger version
ID:	18773   Click image for larger version
ID:	18774   Click image for larger version
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 2 Users Say Thank You to skyking For This Useful Post:
aerohead (09-21-2015), bespurcell (10-23-2015)
