Old 09-23-2015, 01:11 AM   #2065 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by thingstodo View Post
I need a manufacturer and a part number for the round 12 pin connectors in order to get parts - female connector and pins. I am still using the temporary setup.
I got a couple of decent 10 turn 5K pots to use for the throttle before my hall effect throttles arrive. I'm still trying to source them locally - shipping and customs from digikey and mouser kinda suck.
I also got some small pins for the encoder that should work better than what I have right now. I'd like to get the encoder built into the motor working properly.
The EVTV forum has a possible part number for the connector
MA1CAE1200 Amphenol SINE Systems | Mouser
And this manual has a wiring diagram of sorts on page 23 under circuit diagrams
Login - Forum
1 - ua1
2 - ua2
4 - power supply
5 - ground
9 - KTY + blu
10 - KTY - red
11 - KTY + Blk
What is the power supply voltage? I'll have to look through the forums again.
64 pulses per revolution - not exactly great for Paul, but Paul's perfecting the sensorless controller, so the encoder is only for an accurate tachometer!
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (09-23-2015)
