Old 09-23-2015, 11:02 AM   #284 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Still working on your answer. lol
The 2.0 L engine size problem is that even at a needed 4 hp to 6 hp the 2.0L engine would have to be running in vacuum and could not utilize the turbos
FE efficiency at this very light load. On my car I have to overcome AWD drive train loss and with a Cd of .29 so the hp that is needed is around 10 hp @ 55 mph.
So in your case the turbo could help with extra power when needed if you choose to run a 3 valve setup.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
MobilOne (11-13-2015)
