You will find the "obvious to someone educated in the art" clause of the patent examination process to be very tough to surpass with your "innovation" and I would bet that if every patent application was thoroughly investigated, that preceeded your inspiration.
Anytime DFCO is engaged, the charging system and AC systems should both be in maximum charge and cool respectively.
regards
mech
